PHOENIXstudios PC_DIMMER2008 - Version 4.0.5 Build 1380
Fehlerbericht vom 09.01.2008 um 07:50:36
Fehlertyp: EComponentError
Exception address: 0042E77B
Verursacher: TPanel "Panel3"
System : Windows XP Home Edition, Version: 5.1, Build: A28, "Service Pack 2"
Processor: AMD, AMD Turion(tm) 64 X2 Mobile Technology TL-50, 1600 MHz MMX
Display : 1280x800 pixels, 32 bpp
Stack list, generated 09.01.2008 07:50:36
[0042E776] Classes.TComponent.ValidateRename + $56
[004AB0EE] Forms.TCustomForm.ValidateRename + $16
[0042E860] Classes.TComponent.SetName + $58
[0048F19E] Controls.TControl.GetText + $16
[0048EFDD] Controls.TControl.SetName + $6D
[0074D69D] geraetesteuerungfrm.Tgeraetesteuerung.loadDDF_geraetesteuerung (Line 2287, "geraetesteuerungfrm.pas" + 272) + $6B
[007461EF] geraetesteuerungfrm.Tgeraetesteuerung.TreeViewCheckbuttons (Line 1416, "geraetesteuerungfrm.pas" + 190) + $5
[00744F15] geraetesteuerungfrm.Tgeraetesteuerung.TreeviewRefresh (Line 1213, "geraetesteuerungfrm.pas" + 60) + $8
[007442A7] geraetesteuerungfrm.Tgeraetesteuerung.Gerthinzufgen1Click (Line 1063, "geraetesteuerungfrm.pas" + 60) + $3
[004907D4] Controls.TControl.Click + $64
[00485820] StdCtrls.TButton.Click + $1C
[004508C5] Buttons.TBitBtn.Click + $65
[00485914] StdCtrls.TButton.CNCommand + $C
[0049063C] Controls.TControl.WndProc + $188
[004936E3] Controls.TWinControl.WndProc + $157
[004856E4] StdCtrls.TButtonControl.WndProc + $6C
[0049040C] Controls.TControl.Perform + $24
[0049381B] Controls.DoControlMsg + $23
[00493ED3] Controls.TWinControl.WMCommand + $B
[004937C7] Controls.TWinControl.DefaultHandler + $D7
[00493360] Controls.TWinControl.MainWndProc + $2C
[0042FA14] Classes.StdWndProc + $14
[00490BDC] Controls.TControl.WMLButtonUp + $10
[006939A6] TB2Hook.GetMessageHook (Line 138, "TB2Hook.pas" + 9) + $1B
[0049350B] Controls.TWinControl.IsControlMouseMsg + $13
[004B2DE5] Forms.TApplication.StopHintTimer + $15
[004B1FAF] Forms.TApplication.ProcessMessage + $83
[004B1FE6] Forms.TApplication.HandleMessage + $A
[004B2216] Forms.TApplication.Run + $96
[00888930] PC_DIMMER.PC_DIMMER (Line 170, "" + 79) + $2
Active Controls hierarchy:
TComboBox "EffekttimelineCombobox"
TJvCaptionPanel "timeline_panel"
TMainform "MainForm"
Fehlerbericht
Fehlerbericht vom 09.01.2008 um 07:53:52
Verursacher: TTreeView "TreeView1"
Stack list, generated 09.01.2008 07:53:52
[00485209] StdCtrls.TCustomComboBox.WMLButtonDown + $2D
[0074C0E6] geraetesteuerungfrm.Tgeraetesteuerung.loadDDF_geraetesteuerung (Line 2180, "geraetesteuerungfrm.pas" + 165) + $6B
[007471D7] geraetesteuerungfrm.Tgeraetesteuerung.TreeView1MouseUp (Line 1638, "geraetesteuerungfrm.pas" + + $5
[00490B86] Controls.TControl.MouseUp + $2A
[00490BC0] Controls.TControl.DoMouseUp + $2C
[00490C35] Controls.TControl.WMLButtonUp + $69
[00493549] Controls.TWinControl.IsControlMouseMsg + $51
[0046A16B] ComCtrls.TCustomTreeView.WndProc + $83
Hi mathieu,
was hast du genau versucht zu machen? So wie das im Bericht aussieht, hast du ein neues Gerät hinzugefügt und beim Laden des DDF-Bildschirms hat die Software eine Zugriffsverletzung produziert. Da die Zugriffsverletzung bei beiden Meldungen an der gleichen Adresse auftritt, dürfte das Problem die gleiche Quelle haben. Kannst du mal ganz kurz beschreiben, was genau du gemacht hast, sonst kann ich es nicht genauer orten.
In der Version 4.0.5 Build 1380 hatte ich meines Wissens noch einen kleinen Bug drin, dass die Software bei Hinzufügen des ProScan250 einen Fehler "Button 1 existiert schon" produziert. Das ist in den späteren Version behoben - wenn du dieses Gerät laden wolltest, dann wird das die Ursache gewesen sein.
Bis dann,
Bis dann,
