Hello,
Here is a DDF for Showtec Fogjet
Colin
cdvries88
PC_Dimmer_2010_DDF_for_Showtec_Fogjet_by_cdvries88.zip- (89.64 KiB) 531-mal heruntergeladen
Re: DDF for Showtec Fogjet
Hi Colin,
thank you very much for your work on the DDF. I will put the DDF-files to the setup of PC_DIMMER.
kind regards,
kind regards,
cdvries88
Hello Chris,
You're welcome, I had already created them.
It was a little effort to share them with you
Thank you for putting them in the setup of PC_Dimmer
Regards,
Colin
Regards,
Colin
