First of all, thanks a lot for this awesome piece of software. In the past (~5 years ago?) I played a bit with it and found it useful.
Recently I found my dimmer again ("32" channel PC-Dimmer Serial, but only 1 box so 8 channels) so I tried the latest version of PCDimmer, unfortunately it doesn't really work...
What happens: I select the 128channel pcdimmer plugin, use com1 at 9600 boud.
When I touch fader 1, Light 1 swiches to 100%
When I touch fader 8, light 2 switches to 100%
The lights won't fade and won't go out either.
With the original software everything works as expected.
Am I forgetting to configure something? I also tried adding a pcdimmer to the devices list, but this doesn't change anything.
Thanks a lot in advance for your answer!
ps. Antwort kann auch auf's Deutsch geschrieben werden, das kann ich verstehen
